Configuring Siebel eBusiness Applications > Working with the Entity Relationship Designer >
Making Shapes the Same Size
You can use Layout option to make one or more shapes the same size. To make shapes the same size
- Navigate to an entity relationship diagram.
For instructions, see Navigating to Entity Relationship Diagrams.
- In the ERD canvas, select two or more entities by holding down the shift key while clicking the shapes.
- Right-click and then choose Layout > Make Same Size > and one of the following options:
