Configuring Siebel eBusiness Applications > Working with the Entity Relationship Designer >
Adding Points to Lines
You can change the shape of lines, add right angles for example, by adding points to relationship lines. This avoids overlapping lines when a diagram becomes complex. To add points to lines
- Navigate to an entity relationship diagram.
For instructions, see Navigating to Entity Relationship Diagrams.
- In the ERD canvas, select a relationship line.
- Right-click and choose Edit > Add Point.
- With your pointer, grab the point and drag it to a new position on the ERD canvas.
