Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Configuring Siebel eBusiness Applications > Displaying Images > Displaying Images for Field ValuesThe Icon Map object type allows you to render control or list column field values as icons. Each Icon Map is a collection of child objects called Icons. Icon objects are associated with a Bitmap object, which defines the image for the Icon, and corresponds to a particular field value. Controls and list columns have an attribute called Icon Map that allows you to define the icon map object that you want to use for rendering the field values. The following procedure uses an example to show you how to configure icons for use as field values. The example uses the Status list column on the Activity List Applet. Suppose that the Status field can have values Not Started, In Progress, and Done. You want to configure the Status field to display an icon for each of these values. NOTE: If you want to use custom icons in a list applet, you must size them in accordance with the list applet's row font size. For example, when using an 8-pt font (standard for Siebel eBusiness Applications), icons should be 23 pixels in width x 14 pixels in height. If you change the list applet row font size dynamically or place an icon larger than 23 x 14 in a row, the list applet rows will be scrambled. To render fields using Icon Maps
NOTE: You can create an icon named Default in an Icon Map object. If the field value does not match any of the icons, then the Default icon is used for the field. This feature is useful to create an icon to be used with fields that could contain different values, such as URLs. In this case you would set the HTML Type property of the field to be URL and its IconMap property to an IconMap object that contains only one icon named Default. |
Configuring Siebel eBusiness Applications |
