Configuring Siebel eBusiness Applications > Creating and Administering Lists of Values >
Resuming the MLOV Upgrade Utility When Errors Occur
In case of an error, you can resume running the MLOV Upgrade Utility in validation mode or translation mode. To resume the MLOV Upgrade Utility in a Windows environment
- At the DOS prompt, navigate to the BIN directory of your Siebel Server root directory (
SIEBEL_ROOT\BIN ).
- At the command prompt do one of the following:
- To resume running in validation mode, type siebupg
/m master_mlov_verify.ucf
- To resume running in translation mode, type siebupg
/m master_mlov_translate.ucf
To resume the MLOV Upgrade Utility in a UNIX environment
- Navigate to the bin directory of your Siebel Server root directory
( SIEBEL_ROOT /bin).
- At the prompt, do one of the following:
srvrupgwiz /m master_mlov_verify.ucf
- To resume running in translate mode, type
srvrupgwiz /m master_mlov_translate.ucf
