Topics in This Chapter
About Lists of Values
Creating New LOV Types and LOV Values Using Siebel Tools
About Organization Enabled Lists of Values
About Multilingual Lists of Values
About the Language Independent Code
Guidelines for Configuring MLOVs
Process of Enabling MLOVs
Identifying Which Columns to Enable
Checking for Visibility Rules
Making Sure the LOV Type Is Translatable
Determining If the Picklist Is Bounded
Reviewing List of Columns That Cannot be MLOV Enabled
Configuring the Multilingual List of Values in Siebel Tools
Adding Translated Display Values in Application Administration
Upgrading Existing Data Using the MLOV Upgrade Utility
MLOV Upgrade Utility Parameters
Resuming the MLOV Upgrade Utility When Errors Occur
About the MLOV Upgrade Log File
Integration Considerations
Configuration Considerations
MLOV Configuration and Coding Guidelines
About Querying and Multilingual Lists of Values
Configuring Siebel Business Process Designer to Use MLOV-Enabled Fields
Configuring Siebel Assignment Manager to Use MLOV-Enabled Fields
Configuring Siebel Anywhere for Use with MLOV-Enabled Fields
Important Fields in List of Values Administration Views
About Adding Records for MLOV Fields
Deleting Compared to Deactivating MLOV Records
