Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Configuring Siebel eBusiness Applications > Creating and Administering Lists of Values > Configuring Siebel Assignment Manager to Use MLOV-Enabled FieldsAdditional configuration is required to enable Siebel Assignment Manage to use MLOV-enabled fields. Siebel Assignment Manager compares values in target tables with values in Assignment Manager administration tables to determine whether a particular condition is true. For columns enabled for MLOVs, the value stored in the target table is the Language-Independent Code rather than the Display Value. However, the value in the Assignment Manager administration table is the Display Value. Assignment Manager cannot evaluate a condition by comparing the Language-Independent Code to the Display Value. To enable Siebel Assignment Manager to work with MLOV-enabled columns, you must configure Assignment Manager entities so that they compare the language-independent code in the target table with the language-independent code in the Assignment Manager administration table. You must do this for the following entities: Criteria Values and Criteria SkillsBefore configuring Criteria Values and Criteria Skills, you must:
For each of the fields that reference Criteria Values or Criteria Skills (Assignment Attributes), you must set the Translate column to True and define the language-independent code field as the Translate Pick Field. To configure Assignment Criteria and Skills for MLOVs
Workload RulesBefore configuring Workload Rules, you must:
For each of the fields that reference Workload rules, you must complete the following tasks:
The detailed steps for completing these tasks are the same as the steps for configuring Workflow Policy Columns covered in Policy Conditions. For more information about Siebel Assignment Manager, see Siebel Assignment Manager Administration Guide. |
Configuring Siebel eBusiness Applications |
