Configuring Siebel eBusiness Applications > Creating and Administering Lists of Values >
About Adding Records for MLOV Fields
When you add a new list of values record for a LOV type that has been multilingual-enabled, you also need to add records for all supported languages. For example, when adding a new entry for FREIGHT-TERMS type, you need to add values for supported languages.
If you add a new entry and do not add corresponding additional records for each supported language, the language-independent code will be displayed instead of the display value when a user with one of these languages tries to view the information.
Adding records for all the languages you support is also important for Assignment Manager. For more information, refer to Configuration Considerations.
For more information about adding records to the LOV table, see Applications Administration Guide.
