Configuring Siebel eBusiness Applications > Configuring Picklists and Pick Applets >
Configuring a Hierarchical Picklist
To configure a hierarchical picklist
- Configure a parent and a child picklist.
- Set the Business Component property of the parent picklist to Picklist Hierarchical.
- Set the Business Component property of the child picklist to PickList Hierarchical Sub-Area.
- Go to the business component that contains the fields that you want to associate the hierarchical picklists with.
- Set the Picklist property of the parent field to the parent picklist.
- Set the Immediate Post Changes property of the parent field to TRUE.
- Set the PickList property of the child field to the child picklist.
- For the child field, create the following Pick Map objects.
[name of parent field] |
Parent |
TRUE |
[name of child field name] |
Value |
- Compile changes to a repository file.
- Add LOV values using the Parent LIC column to designate the parent value.
See table above for a simple example and see the Constrained Lists of Values section in Applications Administration Guide for a detailed discussion.
- Test.
