Topics in This Chapter
About Links
How Links Are Constructed
Creating Links to Define a 1:M Relationship
Using Two Links to Define a M:M Relationships
About the Cascade Delete Property
About the Search Specification Property
About the Visibility Rule Property
Using the Check No Match Property with a Primary Join
About Multi-Value Links
How Multi-Value Links Are Constructed
How Indirect Multi-Value Links Are Constructed
How a Cascade Copy with a Multi-Value Link Is Constructed
Configuring the Primary ID Field
