Configuring Siebel eBusiness Applications > Configuring Multi-Value Group and Association Applets > About Shuttle AppletsIn high interactivity mode, when a user clicks the MVG button and the business component of the underlying MVG applet has a many-to-many (M:M) relationship with the master business component, a shuttle applet is displayed (shown in Figure 95). Shuttle applets allow users to associate detail records to a parent record and create new records. The underlying object architecture for shuttle applets is the same as the architecture described in Figure 94 for association applets. However, shuttle applets are rendered using two specialized Web templates (CCPopupListAssoc.swt and CCPopupListMVG.swt). Items on shuttle applets come from the repository object definitions of both the association applet and the MVG applet.
The Mode property of the Applet Web Template Item object type determines in which applets the controls appear.
NOTE: Shuttle applets do not support popup applets. You cannot invoke a popup applet from a shuttle applet. For additional information related to shuttle applets, see Release Notes on Siebel SupportWeb. |
Configuring Siebel eBusiness Applications |
