Configuring Siebel eBusiness Applications > Configuring Multi-Value Group and Association Applets > Understanding How MVGs are Implemented >
About the MVG Business Component
This business component stores the detail records of the master-detail relationship with the originating business component. The records displayed in the multi-value-group applet are from the multi-value group business component. The multi-value group business component has no important properties with respect to its role in the implementation of a multi-value group. It has field child object definitions that are used in the following ways:
- To store data for a field in the multi-value group
Each field with this role is represented by a list column in the multi-value group applet. It may also participate in the multi-value link to supply data to a corresponding field in the originating business component.
- To identify the primary record in the multi-value group
Primary records are identified by the primary field which is specified in the Primary Field Id property in the multi-value link.
NOTE: The primary field has nothing to do with the multi-value group business component. It does have relevance to the originating business component, the multi-value link, and the multi-value group applet.
- As the destination field of the link
The field with this role is a foreign key to the originating business component.
