Configuring Siebel eBusiness Applications > Configuring Multi-Value Group and Association Applets >
Creating MVGs Using the MVG Wizard
You can use the MVG Wizard to help you create the necessary relationships between business components and define multi-value fields. To configure a multi-value group using the MVG wizard
- Choose File > New Objects.
The New Object Wizards dialog box appears.
- Under the General Tab, double-click the MVG icon.
The Multi Value Group dialog box appears.
- In the Multi Value Group dialog box, select:
- The project to which the MVG will belong. Only locked projects are available for you to select.
- The master business component. The business component must belong to the selected project.
- Click Next.
- In the second Multi Value Group dialog box, do the following:
- Select the detailed business component.
- Enter a name for the Multi Value Link.
- Click Next.
- In the Direct Links dialog box, select the link that you want to use, and then click Next.
The available links are those that already exist between the master and detail business component.
- In the Primary ID Field, do the following:
- Select the Primary ID Field in the Master Business Component.
- Set the value for the Auto Primary property.
- Select other options as necessary.
- Click Next.
- In the Multi Value Link dialog box, select the properties that you want to define and then click Next.
- In the Multi Value Fields dialog box, enter information for creating multi-value fields on the master business component.
- Select a field on destination business component.
- Enter a name for the multi-value field.
- Click Add.
- Repeat for each field you want to add.
- Click Next.
- In the Finish dialog box, review the information you have entered for the MVG and then click Finish.
