Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Configuring Siebel eBusiness Applications > Overview of Configuring Siebel Applications > About the Siebel Operating Architecture > Enabling and Disabling High Interactivity for ApplicationsEmployee applications are set to use high interactivity mode by default. You can also set employee applications to run in standard interactivity mode. The mode is determined by a parameter in the application configuration file. NOTE: high interactivity is not supported for customer applications. To enable or disable high interactivity
Configuring Siebel eBusiness Applications |
