Configuring Siebel eBusiness Applications > Overview of Configuring Siebel Applications > About the Siebel Object ArchitectureThe metadata that defines Siebel applications, objects, and other files such as Web templates and style sheets, can be divided into the following architectural layers:
The four-layer architecture is shown in Figure 1. Objects in each layer of the Siebel object architecture are insulated from the layers above it and below it, including the DBMS at the bottom of the architecture. This allows you to change or extend Siebel objects in one layer without impacting other layers. Similarly, because the database in the DBMS is separated from the object architecture, you can make database changes with only minimal impact to the applications. |
| Configuring Siebel eBusiness Applications |
