Configuring Siebel eBusiness Applications > Configuring Special Purpose Applets > Configuring Attachment TablesAttachment tables provide the underlying data storage for the attachment business components. Unlike the attachment business component, which can support purposes in addition to file engine functionality, the attachment table stores file engine data only. Users will not populate the attachment table directly. Rather, users are provided with an initially empty attachment table, and populate it one file at a time using drag and drop or the browser dialog box in the corresponding file attachment applet. Table 65 lists the columns that appear in an attachment table. Note that the columns whose names begin with FILE_ are required columns, and must be named as specified in the table. The User Name values can be the same as or different from those listed. Various system columns not related to the file engine will also be present, such as CREATED, LAST_UPD_BY, and ROW_ID. A table that has file engine columns must be flagged as such with a TRUE value in the File property of the corresponding table object definition. |
| Configuring Siebel eBusiness Applications |
