Configuring Siebel eBusiness Applications > Configuring Spell Check >
Creating a Spell Check Button
To create a Spell Check button
- In the Object Explorer, double-click the Applet object type to expand it.
- In the Applets window, select the name of the applet for which you are creating a Spell Check button.
- In the Object Explorer, select the Control object type and add a new record.
Create the new record with the following values:
Values for Non-Required Fields |
Values for Required Fields |
Name |
ButtonCheckSpelling |
Caption |
Check Spelling |
Check Spelling |
Field |
[field name] |
leave blank |
HTML Type |
MiniButton |
MiniButton |
HTML Only |
True |
True |
Method Invoked |
ShowPopup |
ShowPopup |
NOTE: If the Method Invoked value does not appear in the picklist, type it in.
