Configuring Siebel eBusiness Applications > Configuring Spell Check >
Process for Configuring Spell Check
To configure spell check, perform the following tasks:
  1. Create a Spell Check button. You need to create a Spell Check button for the applet containing the field to be checked. For information on performing this procedure, see Creating a Spell Check Button.
  2. Set the Spell Check button user properties. For information on performing this procedure, see Defining Spell Check Button User Properties.
  3. Edit the Web Applet template. After creating a Spell Check button, you add it to the template where it will appear. For information on performing this procedure, see Adding Spell Check Button to a Web Template.
  4. Add the Spell Check business component to a business object. Next, you add the Spell Check business component to the business object of the applet containing the field to be checked. For information on performing this procedure, see Associating Spell Check Business Component to a Business Object.
  5. Create a Spell Check menu item. You need to create a Spell Check menu item for the applet containing the field you want to be checked. For information on performing this procedure, see Creating a Spell Check Menu Item.
NOTE:  If you want to configure spell check for multiple fields on an applet, you must create a button for each field (tasks 1, 2, and 3).
