Configuring Siebel eBusiness Applications > Configuring Spell Check >
Creating a Spell Check Menu Item
To create a Spell Check Menu Item
- In the Object Explorer, click Applet, and then select the applet for which you want to create a Spell Check menu item.
- Double-click the Applet object type to expand it, and then select Applet Method Menu Item.
- In the Applet Method Menu Item window, add a new record.
Create the new record with the following values:
Command |
Check Spelling |
Menu Text |
&Check Spelling |
Position |
2 |
- If the field you are configuring for spell check is required, then do the following:
- Select the Applet User Property object type.
- In the Applet User Properties window, add a new record using following values:
Name |
Check Spelling Field |
Value |
[Name of the control or list column mapped to the field that will use Spell Check] |
