Configuring Siebel eBusiness Applications > Configuring Spell Check >
Associating Spell Check Business Component to a Business Object
To add the Spell Check business component to a business object
- In the Object Explorer, click the Business Object type.
- In the Business Objects window, select the business object to which you want to add the Spell Check business component.
- In the Object Explorer, double-click Business Object to expand it, and then select Business Object Component.
- In the Business Object Component (child) window, add a new record.
Create the new record with the following values:
BusComp |
Spell Checker Applet VBC |
