Configuring Siebel eBusiness Applications > Configuring Toolbars and Menus > About Toolbars and Menus > About the Command Object TypeA Command object definition specifies which invoke method is called when a toolbar icon or application-level menu item associated with the command is executed (applet-level menus do not use command objects). It also specifies which bitmap appears on the toolbar icon for toolbar items. Command object definitions are referenced by Toolbar Item or Menu Item object definitions. For more information about creating Command objects, see Creating Command Objects. A Command object definition has the following significant properties:
| Configuring Siebel eBusiness Applications |
