Configuring Siebel eBusiness Applications > Configuring Toolbars and Menus > About Toolbars and Menus > About the Toolbar Object TypeFor each toolbar in the application, you create a Toolbar object definition in the Object List Editor. This provides a named toolbar that the user can activate or deactivate in Siebel applications, and to which icons (Toolbar Item object definitions) can be associated or removed. Typical toolbar functionality for most applications is implemented using HTML toolbars. In an HTML toolbar, the buttons are static images, which may be dimmed to indicate unavailability, but otherwise are not manipulated by program logic on the browser. In contrast, communications toolbars in applications such as Call Center, require toolbar icons that can be altered in response to events, such as blinking a particular toolbar icon when a call is incoming. This requires the use of Java toolbars. To specify that a toolbar is of the Java type, a class name is entered in the Class property. For more information about configuring communications toolbars, see Siebel Communications Server Administration Guide. Important properties of Toolbar are:
| Configuring Siebel eBusiness Applications |
