Configuring Siebel eBusiness Applications > Overview of Web Templates and Siebel Tags > About Siebel Tags > About Singleton and Multi-Part TagsSingleton and multi-part tags are part of the basic vocabulary of SGML, so they are only discussed here to introduce the concepts and terminology. Siebel eBusiness Applications use singleton and multi-part tags in the standard way. A singleton element is a tag that includes the end-tag slash in the same tag as the tag name. There are no child elements in a singleton tag. The following is an example of a singleton tag: The following is an example of a multi-part tag because it does not have the end-tag slash: |
| Configuring Siebel eBusiness Applications |
