Configuring Siebel eBusiness Applications > Overview of Web Templates and Siebel Tags > About Siebel Tags > About Nesting and Siebel TagsYou cannot nest a Siebel tag inside HTML tags. For example, the following is not valid and will generate an error:
In addition, you cannot nest some Siebel tags. For example, the following is not valid and will generate an error:
| Configuring Siebel eBusiness Applications |
