Siebel Financial Services Connector for ACORD P&C and Surety Guide > Configuration Roadmap > Configuring the Connector Components > FINS ACORD XML DispatcherTwo user properties need to be set to new values for your specific case, as listed in Table 26. In the dispatcher user properties, fill in the names of the dispatcher map and envelope integration objects that are created by FINS ACORD Wizard. NOTE: After configuring each business service, you need to compile the new business service definition into the application repository file. The procedure is the same as compiling an integration object. For instructions, see Viewing the Dispatcher Map. |
Siebel Financial Services Connector for ACORD P&C and Surety Guide |
