Table 13. Argument Values for FINS ACORD XML Converter Methods
    | ClientApplicationOrganization | <Client application organization name> | The value for <Org> in < ClientApp> |
    | ClientApplicationName | <Client application name> | The value for <Name > in < ClientApp> |
    | ClientApplicationVersion | <Client application version> | The value for <Version> in < ClientApp> |
    | IsClient | true, false | "True" if Siebel FINS is behaving as an ACORD client. "False" if Siebel FINS is behaving as an ACORD server. |
    | IsSignoff | true, false | If "true," the converter generates a SignoffRq aggregate for the current ACORD document. If "false," the converter does not generate a SignoffRq aggregate. |
    | ServiceProviderName | <ACORD service provider name> | The value will be used as the value of <SPName> in <SignonRq> aggregate. |
    | XMLEnvIntObjectName | <Name of the envelope integration object> | Name of the integration object that defines ACORD envelope. |
    | SignonRsEcho | <Property Set storing echo values from SignonRq> | Those echo values are used by SignonRs header. |
    | initsignon | <Integration component user property of envelope integration object> | Determine which user property in envelope integration object will be used to construct initial SignonRq header.  |
    | sessionsignon | <Integration component user property of envelope integration object> | Determine which user property in envelope integration object will be used to construct subsequent SignonRq header. |
    | signonRs | <Integration component user property of envelope integration object> | Determine which user property in envelope integration object will be used to construct SignonRs header. |
    | signoffRq | <Integration component user property of envelope integration object> | Determine which user property in envelope integration object will be used to construct SignoffRq header. |
    | signoffRs | <Integration component user property of envelope integration object> | Determine which user property in envelope integration object will be used to construct SignoffRs header. |
    | ErrorCode | <Error code value> | The error code during operation to be set in the ACORD Status header. |
    | ErrorMessageText | <Error message text> | The actual error message during operation to be set in the ACORD Status header. |
    | GeneralErrorMessageText | <Error message text> | The generic error text to be pre-appended to the actual error text. For example, "The error happens before the transaction manager." |
