Siebel Financial Services Connector for IAA-XML Guide > Configuration Roadmap >
Configuring Outbound and Inbound Integration
Siebel eBusiness Applications provide several sample workflows as reference implementations in the Sample database that can be either used as is or you can modify them based on your business requirement before using them in your environment. The following sections walks you through two of these sample workflow. NOTE: For details on Siebel Workflow, see Siebel Business Process Designer Administration Guide.
