Siebel Financial Services Connector for IAA-XML Guide > Configuration Roadmap > Configuring Outbound and Inbound Integration > Sample Workflow IAA Add Party Outbound WorkflowThis is a sample workflow process that gets Contact information from database and converts it into IAA-XML AddPartyRequest format. This IAA-XML message is then sent to MQ Series. Other Applications will be able to retrieve the message from MQ. Figure 5 shows the graphical representation of the IAA Add Party Outbound workflow. Process propertiesThe IAA Add Party Outbound Workflow process has the following properties. NOTE: You set workflow process properties when you need a property that will be global to the entire workflow. The first step, after Start, uses the FINS IAA-XML Transaction Manager to query a party from your Siebel application, using the following input and output arguments. Input ArgumentsOutput ArgumentsThe second business service transforms the information using the FINS IAA-XML Data Transformation Engine business service with the Transform To External Hierarchy and following input and output arguments. Input ArgumentsOutput ArgumentsThe third business service invokes the FINS IAA-XML Converter with the PropSetToXMLPropSet method to convert the IAA-XML Hierarchy to an IAA-XML String with the input and output arguments shown below. Input ArgumentsOutput ArgumentsThe result of this step is stored in output argument Converter Request Prop Set. As the last step of the workflow, the forth business service of the workflow invokes the XML Hierarchy Converter with the XML Hierarchy to XML Document method to generate the outgoing XML document using the input and output arguments shown below. Input ArgumentsOutput Arguments |
| Siebel Financial Services Connector for IAA-XML Guide |
