Siebel Financial Services Connector for IAA-XML Guide > Configuration Roadmap > Siebel Connector for IAA-XML Configuration OverviewThe Siebel Connector for IAA-XML comprises of four pre-built business services:
The Siebel Connector for IAA-XML can be configured to support several types of IAA Business Object Model packages. Figure 3 illustrates the main steps in configuring the Siebel Connector for IAA-XML. The following checklist and figure shows the high-level procedure for configuring your system to use the Siebel Connector for IAA-XML.
To illustrate this procedure consider a scenario where Siebel Financial Services application sends a newly created contact to an external application for adding it to its database and also receives a newly generated contact record from an external applications to add to Siebel database. This illustration corresponds to the <AddPartyRequest> and <AddPartyResponse> commands in IAA-XML. We use the MQ Server Transport in this configuration roadmap but you can use other transports when applicable. | ||||||||||||||||||||
| Siebel Financial Services Connector for IAA-XML Guide |
