Deployment Planning Guide > Siebel Infrastructure Planning >
Process of Infrastructure Planning
This process shows you how to determine the Siebel infrastructure requirements for a production environment. Along with a production environment, you should also plan for a software development and a test environment. Use the following steps to plan your Siebel deployment infrastructure:
- Determining How the System Will Be Used
- Defining Data Flows and Integration Requirements
- Determining Database Requirements
- Mapping Business Requirements to Siebel Server Components
- Defining High-Availability Policies
- Mapping Siebel Deployment Elements to Platforms
- Determining Network Requirements
- Defining a Test and Transition Plan for the Siebel Deployment
