Developing and Deploying Siebel eBusiness Applications > Configuring the House and Opportunity Entities > Configuring the House Detail - Appraisals View >
Compiling and Unit Testing
After you have completed your configuration work, do the following.
- Compile your changes.
- Register the House Detail - Appraisals View in the application.
- Add House Detail - Appraisals View to a responsibility that you can use to test.
- Unit Test your work.
Figure 19 shows the House Detail - Appraisals View as it is rendered at run time.
Figure 19. House Detail - Appraisals View
