Developing and Deploying Siebel eBusiness Applications > Creating a Virtual Business Component > Creating a Virtual Business Component > Defining User Properties for the Virtual Business ComponentThe user properties required by the NREC Renovations VBC are Service Name and Service Parameters. The Service Name user property defines which business service the VBC invokes. The Service Parameters define the parameters that are passed into the business service upon initialization. In this example, the parameters are defined in the script attached to the business service. Read the Pal_Init function in the Code Samples. To define virtual business component user properties NOTE: If the Business Component User Prop is not visible in the Object Explorer, then you need to make it visible by choosing View > Options to display the Development Tools Options dialog box, then clicking the Object Explorer tab. The check box for Business Component User Prop is in the Business Component hierarchy.
| Developing and Deploying Siebel eBusiness Applications |
