Overview: Siebel Enterprise Application Integration > Siebel EAI Overview > About Application Services InterfacesAn Application Services Interface (ASI) is a release-independent interface published by Siebel Systems that allows you to integrate Siebel applications with external applications. ASIs are published in a standard metadata format, such as Extensible Markup Language Document Type Definitions (XML DTD) and Web Services Descriptive Language/XML Schemas (WSDL/XSD) and are built using the ASI Framework. There are two types of ASIs, Inbound ASIs and Outbound ASIs. Inbound ASI is used to accept data into Siebel applications from an external system using Siebel workflows, Siebel Business Services, and Siebel Data Synchronization services through the Siebel Object Manager as illustrated in Figure 6. An Outbound ASI is used to send data out based on a UI event or a trigger in your Siebel workflow as illustrated in Figure 7. NOTE: For details on ASIs, see Application Services Interface Reference. |
| Overview: Siebel Enterprise Application Integration |
