Integration Platform Technologies: Siebel Enterprise Application Integration > Integration Objects > Permission Flags for Integration ComponentsEach business component, link, MVG, and integration object user property has settings such as No Update, No Delete, and No Insert. These settings indicate the type of operations that cannot be performed on that object. In order for the EAI Siebel Adapter to successfully perform an operation, that operation must be allowed at all levels. If the operation is allowed at every level except the field level, a warning message is logged in the log file and processing continues. Otherwise, an error message is returned, and the transaction is rolled back. You set the permission settings by using user properties on the integration object, component, or field. Table 6 illustrates which permissions influence which operation type on an integration component. NOTE: The transaction is rolled back if any of the permissions (excluding field-level permissions) are denied. |
| Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
