Integration Platform Technologies: Siebel Enterprise Application Integration > EAI UI Data Adapter > EAI UI Data Adapter Methods > InitLeaves MethodUse InitLeaves to retrieve pre-default values. When InitLeaves is invoked on an integration object hierarchy, it retrieves the pre-default values for all leaf nodes. All internal nodes must exist in the database and Row Id must be specified. InitLeaves Method ArgumentsTable 31 lists the method arguments used with the InitLeaves Method. For a complete description of the method arguments, see EAI UI Data Adapter Method Arguments. Example of Using InitLeaves on a Root ComponentThe following code snippet demonstrates using InitLeaves to retrieve default values for a root component. In this example the root component is Account. Request<?xml version="1.0" encoding="UTF-8"?> Response<?xml version="1.0" encoding="UTF-8"?> Example of Using InitLeaves on a Child ComponentThe following code snippets demonstrate using InitLeaves to retrieve pre-default values for a child component. In this example the parent component is Account and the child component is Business Address. Request<?xml version="1.0" encoding="UTF-8"?> Response<?xml version="1.0" encoding="UTF-8"?> |
| Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
