Integration Platform Technologies: Siebel Enterprise Application Integration > EAI Siebel Adapter > About the EAI Siebel AdapterThe EAI Siebel Adapter is a general purpose integration business service that allows you to:
Node Types and the EAI Siebel AdapterIn an integration object hierarchy, nodes with at least one child are called internal nodes and nodes without children are called leaf nodes. When either the insert or update method is called on the EAI Siebel Adapter, the adapter performs the operation on both internal nodes and leaf nodes. When the insert or update method is called on the EAI UI Data Adapter, the adapter performs insert on leaf nodes only. For more information on node types, see About the EAI UI Data Adapter Business Service. |
| Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
