The EAI Siebel Adapter is a preconfigured business service that is used with any integration process that runs through the Siebel business object layer. Integration objects are used to update data in business objects and are used when retrieving data from business objects. These integration objects are configurable and can be used during an integration process (for example, entering and retrieving data from the Siebel Business Application). This chapter describes the functionality of the EAI Siebel Adapter, and the different methods and arguments you can use with the EAI Siebel Adapter to manipulate the data in the Siebel Database. The following topics are included:
