Integration Platform Technologies: Siebel Enterprise Application Integration > EAI Siebel Adapter > About Using Language-Independent Code with the EAI Siebel AdapterIf the user Property AllLangIndependentVals is set to Y at the integration object level, then the EAI Siebel Adapter uses the language-independent code for its LOVs. In the outbound direction, for example, the Query method, if the AllLangIndependentVals is set to Y, then the EAI Siebel Adapter translates the language-dependent values in the Siebel Database to their language-independent counterpart based on the List Of Values entries in the database. In the inbound direction, for example the Synchronize method, if the AllLangIndependentVals is set to Y, then the EAI Siebel Adapter expects language-independent values in the input message, and translates them to language-dependent values based on the current language setting and the entries in the List Of Values in the database. NOTE: The LOV-based fields are always validated using language-dependent values. Using language independent values for LOVs and MLOVs increases the EAI Siebel Adapter CPU usage by about five percent, but allows easier communication between systems that operate on different languages. About LOV Translation and the EAI Siebel AdapterThe Siebel application distinguishes two types of lists of values (LOV): multilingual LOV (MLOV) and single-language LOV. Multilingual LOV (MLOV) stores a language-independent code (LIC) in the Siebel Database that is translated to a language-dependent value (LDV) for active language by Object Manager. MLOVs are distinguished by having the Translation Table specified in the Column definition. Single-language LOV stores the LDV for the current language in the Siebel Database. The Boolean integration object user property AllLangIndependentVals determines whether the EAI Siebel Adapter should use LDV (N = no translation necessary) or LIC (Y = translation needed) for such LOVs. Translating to LIC affects the performance, but allows easier cooperation between systems that operate on different languages. This option should be especially used by various import and export utilities. The default value is undefined for backward compatibility with the behavior of release 6.x. Table 24 explains the behavior of the EAI Siebel Adapter according to the integration object user property AllLangIndependentVals values. |
| Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
