Integration Platform Technologies: Siebel Enterprise Application Integration > EAI Siebel Adapter >
Enabling Siebel Argument Tracing
You can also export input and output arguments in XML format to a file for the EAI Siebel Adapter. These XML files represent the input and output arguments integration object instances. This is a useful technique as it writes to a file the integration object instances in the directory where your Siebel process is running. For example, in the Siebel Developer Web Client, it is c:/siebel/bin. To enable output arguments tracing
- Set the server parameter EnableServiceArgTracing to True:
- If you are running the Siebel Developer Web Client, add the following to your .cfg file:
[EAISubsys]
EnableServiceArgTracing = TRUE
- If you are running the Siebel Web Client, modify the following Siebel Server parameter for your object manager:
"EnableServiceArgTracing" = true
- Set the appropriate component event level on your server component through the server manager on the server or SIEBEL_LOG_EVENTS in the Siebel Developer Web Client.
If you set event to:
- =3, then input arguments will be written out to a file when an error happens.
- =4, then input and output arguments will be written to a file.
