Integration Platform Technologies: Siebel Enterprise Application Integration > EAI Siebel Adapter >
EAI Siebel Adapter Method Arguments
Each of the EAI Siebel Adapter methods takes arguments that allow you to specify required and optional information to the adapter. You can locate the arguments for each method in Table 22.
Table 22. EAI Siebel Adapter Method Arguments
Argument
Query
QueryPage
Sync
Upsert
Update
Insert
Delete
Execute
IntObjectName
Input
Input
NumOutputObjects
Output
Output
Output
Output
Output
Output
Output
Output
OutputIntObjectName
Input
Input
Input
PrimaryRowId
Input
Output
Output
Output
Output
Input
Input/Output
QueryByUserKey
Input
Input
DeleteByUserKey
Input
Input
ErrorOnNonExistingDelete
Input
Input
SiebelMessage
Input/Output
Output
Input/Output
Input/Output
Input/Output
Input/Output
Input/Output
Input/Output
SearchSpec
Input
Input
Input
Input
StatusObject
Input
Input
Input
Input
Input
Input
MessageId
Input
Input
Input
Input
Input
Input
Input
Input
BusObjCacheSize
Input
Input
Input
Input
Input
Input
Input
Input
LastPage
Output
Output
NewQuery
Input
Input
PageSize
Input
Input
StartRowNum
Input
Input
ViewMode
Input
Input
Input
Input
Input
Input
Input
Input
SortSpec
Input
Input
Table 23 presents each argument of the EAI Siebel Adapter methods.
Table 23. Defining EAI Siebel Adapter Method Arguments
Argument
Display Name
Description
IntObjectName
Integration Object Name
Name of the integration object to delete.
NumOutputObjects
Number of Output Integration Objects
Number of output integration objects.
OutputIntObjectName
Output Integration Object Name
The name of the integration object that is to be output.
PrimaryRowId
Object Id
The PrimaryRowId refers to the Id field in the Business Component, Row_Id at the table level.
PrimaryRowId is only returned as an output argument if you are passing in one integration object instance. If you are passing multiple integration object instances, then this argument is not returned as an output argument. To obtain the ID field when multiple integration objects are processed, use the StatusObject argument.
Query By Key
A Boolean argument. Forces the EAI Siebel Adapter to use only the user keys to perform a query.
Delete By User Key
A Boolean argument. Forces the EAI Siebel Adapter to use only the user keys to identify a record.
Error On Non Existing Delete
A Boolean argument. Determines whether or not the EAI Siebel Adapter should abort the operation if no match is found.
SiebelMessage
Siebel Message
The input or the output integration object instance.
searchspec
Search Specification
This argument allows you to specify complex search specifications as free text in a single method argument. For information, see About Using Language-Independent Code with the EAI Siebel Adapter.
StatusObject
Status Object
This argument tells the EAI Siebel Adapter whether or not to return a status message.
MessageId
Message Id
The MessageId can be used to specify the ID for the generated message. By default, the EAI Siebel Adapter generates a unique ID for each message. However, if you want to use the workflow process instance ID, then you can use this argument to specify the ID.
BusObjCacheSize
Business Object Cache Size
Default is 5. Maximum number of Business Objects instances cached by the current instance of the EAI Siebel Adapter. If set to zero, then the EAI Siebel Adapter does not use the cache.
LastPage
Last Page
Boolean indicating whether or not the last record in the query result set has been returned.
NewQuery
New Query
Default is False. Boolean indicating whether a new query should be executed. If set to True, a new query is executed flushing the cache for that particular integration object.
PageSize
Page Size
Default is 10. Indicates the maximum number of integration object instances to be returned.
StartRowNum
Starting Row Number
Default is 0 (first page). Indicates the row in the result set for the QueryPage method to start retrieving a page of records.
ViewMode
View Mode
Default is All. Visibility mode to be applied to the Business Object. Valid values are: Manager, Sales Rep, Personal, Organization, Sub-Organization, Group, Catalog, and All. Note that the ViewMode user property on the integration object has priority over the ViewMode method argument.
SortSpec
Sort Specification
Default is the SortSpec of the underlying business component. This argument allows you to specify complex sort criteria as a free text in a single method argument, using any business component fields and standard Siebel sort syntax—for examples, see Using Siebel Tools.
About the SearchSpec Input Method Argument
The SearchSpec input method argument is applicable to the QueryPage, Query, Delete, and Execute methods. This method argument allows you to specify complex search specifications as free text in a single method argument. Expressions within a single integration component are restricted only by the Siebel Query Language supported by the Object Manager. Integration components and fields are referenced using the following notation:
[IntCompName.IntCompFieldName]
For example, given an integration object definition with two integration components, Account as the root component and Contact as the child component, the following search specification is allowed:
([Account.Site] LIKE "A*" OR [Account.Site] IS NULL) AND [Contact.PhoneNumber] IS NOT NULL
This search specification queries accounts that either have a site that starts with the character A, or do not have a site specified. In addition, for the queried accounts, it queries only those associated contacts that have a phone number.
NOTE:  The operator between fields for a particular integration component instance can be AND unless between the same field. You use DOT notation to refer to integration components and their fields.
You can include the child integration component in a search specification only if its parent components are also included.
Integration Platform Technologies: Siebel Enterprise Application Integration Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices.
