Integration Platform Technologies: Siebel Enterprise Application Integration > Siebel Virtual Business Components > Search-Spec Node-Type ValuesThe search-string is in the Siebel query language format. The search-string is parsed by the Siebel query object and then turned into the hierarchical search-spec. Table 42 shows the different search-spec node-types and their values. |
| Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
