Integration Platform Technologies: Siebel Enterprise Application Integration > Web Services > About Siebel Authentication and Session Management SOAP Headers >
Session Time Out and Max Age Parameters
You control the session time out length and maximum age by setting the parameters listed in Table 11. These parameters are set in the eapps.cfg file, which is located in the SWEAPP_ROOT\bin directory, where SWEAPP_ROOT is the directory in which you installed the SWSE
Table 11. Session Token TimeOut and MaxAge Parameters
SesionTokenTimeout |
Number in minutes |
Number of minutes a session can remain inactive before the user is logged out and the session is closed. |
SessionTokenMaxAge |
Number in minutes |
The total number of minutes a session can remain open before the user is logged out and the session is closed. |
