Transports and Interfaces: Siebel Enterprise Application Integration > Java Message Service Transport > Enabling Authentication and Authorization for the EAI JMS Transport > Configuring Against IBM WebSphere MQFor the IBM Websphere MQSeries client, no separate security context is needed for each operation. Once a connection is established, all requests sent through the same connection will use the same connection context. NOTE: The MQ server does not perform authentication by default. By default, passwords are not validated. Setup authentication for MQ is a task for the MQ administrator, not the Siebel application administrator. For the ReceiveDispatchSend method, the implication is that the receive credentials must be the same as the send credentials. Receive and send must be executed on the same session or connection to remain a single transaction. To configure Siebel JMS business service against MQSeries
| Transports and Interfaces: Siebel Enterprise Application Integration |
