Transports and Interfaces: Siebel Enterprise Application Integration > Integrating with Java > About Running the Java Data Bean >
Connection Parameters for the SiebelDataBean
Regardless of how the SiebelDataBean is invoked, certain parameters of the connection may be set using the properties file. These are siebel.conmgr.txtimeout, siebel.conmgr.poolsize, siebel.conmgr.sesstimeout, siebel.conmgr.retry, and siebel.conmgr.jce. Other connection parameters may also be specified in the properties file, but they are used only in conjunction with generated code (subclasses of com.siebel.integration.adapter.SiebelJDBAdapterBase or SiebelJCAAdapterBase). The following table, Table 31, gives the details of these parameters.
Table 31. Properties in the siebel.properties File
siebel.conmgr.txtimeout |
The number of milliseconds to wait after sending a request to the Siebel Server. Must be a positive integer; other values are ignored. The default is 600000 milliseconds (10 minutes). |
siebel.conmgr.poolsize |
For each object manager process, a pool of open connections is maintained and shared by all users of that process. This parameter specifies the maximum number of connections that will be stored in the pool. Its value must be a positive integer less than 500; other values are ignored. The default is 2. |
siebel.conmgr.sesstimeout |
The number of seconds the Siebel Server will wait before disconnecting an idle client session. Its value must be a nonnegative integer. The default is 2700 seconds (45 minutes). |
siebel.conmgr.jce |
Determines whether encryption of transmissions is done using Java Cryptography Extension or RSA (if the connection uses encryption). 1 indicates JCE; 0 indicates RSA. The default is 0. |
The number of attempts to be made at establishing a connection (opening a session) before giving up. Must be a positive integer. The default is 3. |
siebel.conmgr.virtualhosts |
A listing of virtual servers representing a group of like servers that perform the same function, for example, call center functions. An incoming login for the call center Virtual Server will try servers from the list in a round-robin fashion. An example of such a list follows: VirtualServer1=sid1:host:port,sid2:host:port...;VirtualServer2=...
where: Virtual Servers = an assigned list of real Siebel Servers with host names and port numbers (of the local SCB).
siebel.connection.string |
The Siebel connect string. For information on the syntax of the connect string, see the Siebel Object Interfaces Reference guide. |
siebel.loglevel |
The level of messages to be logged. Must be a positive integer less than 6. Other values are ignored or throw an exception. 0 causes only FATAL messages to be logged; 1 ERROR; 2 WARN; 3 INFO; 4 DETAIL; 5 DEBUG. The default is 0. NOTE: The siebel.loglevel parameter is used only in conjunction with the generated code for the SiebelJCAAdapterBase subclass.
siebel.logfile |
The name of a file to which logging should be directed. Strings that cause a FileNotFoundException cause an error to be logged and are ignored. The default is to print to the JVM's standard output. NOTE: The siebel.logfile parameter is used only in conjunction with generated code for the SiebelJCAAdapterBase subclass.
siebel.user.name |
The Siebel username to be used for logging in to the Siebel Object Manager. |
siebel.user.password |
The Siebel password to be used for logging in to the Siebel Object Manager. |
siebel.user.language |
The language code indicating the natural language to be used for messages and other strings. Default is enu. |
siebel.jdb.classname |
The name of a subclass of com.siebel.data.SiebelDataBean to use instead of SiebelDataBean. Strings that do not specify a valid class or specify a class that is not a subclass of SiebelDataBean cause an error log to be logged and SiebelDataBean to be used instead. |
Here is a sample siebel.properties file: siebel.connection.string = siebel:// 172.20.94.55:2321/siebel/EAIObjMgr_enu
siebel.user.name = User1
siebel.user.password = password
siebel.user.language = enu
siebel.user.encrypted = false
siebel.conmgr.txtimeout = 3600
siebel.conmgr.poolsize = 5
siebel.conmgr.sesstimeout = 300000
siebel.conmgr.retry = 5
siebel.conmgr.jce = 1
siebel.loglevel = 0
