Delete File after Receive |
DeleteFile |
Default is False. A value of True means that an attempt is made to delete the file after receiving it. If permissions prevent deletion, no error is given, but the information is traced. |
File Name |
FileName |
The name of the file to be received by the file transport. For the Send method, if a file name is not provided, a random name is used for the output file. You must specify an explicit path for file name. You can also use $$ as the wildcard symbol in the file name. For example, if you specify a file name of "file$$.xml," then Siebel creates files like file1-134.xml, fileA25.xml, and file242_12B.xml. For the Receive method, a specific file name must be provided. The use of wildcards such as $$ is not allowed. The source file is deleted upon receiving if set to True. If set to False (the default), the source file is not deleted. |
