Business Processes and Rules: Siebel eBusiness Application Integration Volume IV > Data Mapping Using the Siebel Data Mapper > The Siebel Data Mapper >
Integration Field Maps
Integration field maps specify how fields in the source integration object are mapped to fields in the target integration component. An integration field map target is always a field in the target component of the parent component. An integration field map source can be a constant, a reference to a map argument, a field in the source component, or other legally addressable components such as ancestors of the source component. It can also be a Siebel Query Language expression using one or more of the preceding elements. NOTE: For details on integration field maps, see Creating Integration Field Maps. For details on addressing fields in components other than the source component, see Addressing Fields in Components. For details on Source Expression, see Source Expression.
