| Bookshelf Home | Contents | Index | PDF |    |
| Business Processes and Rules: Siebel eBusiness Application Integration Volume IV > Data Mapping Using Scripts > Siebel Message Objects and Methods > CSSEAIIntObjOutThis object represents an output integration object, open for writing, that is contained in the integration message. It provides CreatePrimaryIntComp and NewInstance methods as an interface to the output integration object. CreatePrimaryIntComp() MethodThis method creates a new primary integration component. Table 23 presents the parameter for this method. SyntaxReturnsCSSEAIPrimaryIntCompOut Primary Integration Component, open for output UsageUse the Exists method to test for existence of the integration object instance, then create a new integration object instance and set it as the active instance, using the NewInstance method. You must perform these tasks before calling the CreatePrimaryIntComp() method. NewInstance() MethodThis method creates a new instance of an integration object and makes it the active instance. SyntaxReturns |
| Business Processes and Rules: Siebel eBusiness Application Integration Volume IV |
