| Bookshelf Home | Contents | Index | PDF |    |
| Business Processes and Rules: Siebel eBusiness Application Integration Volume IV > Data Mapping Using Scripts > OverviewYou can accomplish your data transformation requirements in Siebel eBusiness applications by using the Data Transformation Function or Siebel Data Mapper, as illustrated in Figure 10. For customers who want to do data mapping within Siebel applications, Siebel applications now support two data mapping solutions—Siebel Data Mapper and Siebel eScript Data Mapping. Siebel Data Mapper has a declarative interface and requires no programming skills. Siebel eScript Data Mapping uses scripts programmed in eScript as data maps. Data maps defined using Siebel Data Mapper are easy to maintain and upgrade. These maps also perform better than eScript Data Maps. Because Siebel Data Mapper is based on a declarative interface, it does not have the full flexibility and power that the data mapping using eScript has. Siebel Data Mapper should suffice for most integration needs except some complex mapping situations requiring aggregation, joins, or programmatic flow control. The following checklist outlines the main steps required to accomplish your data transformation requirements using the Data Transformation Functions.
| Business Processes and Rules: Siebel eBusiness Application Integration Volume IV |
