| Bookshelf Home | Contents | Index | PDF |    |
| Business Processes and Rules: Siebel eBusiness Application Integration Volume IV > Data Mapping Using Scripts > XML Property Set Functions > Top-Level Property Set FunctionsThese functions are used to manipulate the top-level property set passed to the Map function. XPSGetRootElement()This function returns the property set representing the root element of the XML document. If the root element is not present, the system raises an error. Table 44 presents the parameter for this function. SyntaxXPSGetRootElement(xmlPropSetIn)
 ReturnsUsageUse this function to return the root element of an XML document. XPSCreateRootElement()This function creates the root element in an output XML document and returns the property set representing it. The element tag in the XML document is set to the value of the tagName argument. Table 45 presents the parameters for this function. SyntaxXPSCreateRootElement(xmlPropSetOut, tagName)
 ReturnsUsageUse this function to create the root element of an XML document that represents a property set. Because the root element does not directly map to a component in the property set, you can give it any representative name. As an example of how the XPSGetRootElement() and XPSCreateRootElement() functions work, consider the following XML document: <?xml version="1.0"?> The root element is <letter>. The property set for the <letter> element can be retrieved from the input property set using EAIXPS_GetRootElement, or it can be created in the output property set using EAIXPS_CreateRootElement. A map function that converts a letter to a memo might start with the following code: function ConvertLetterToMemo (xmlPropSetIn, xmlPropSetOut) |
| Business Processes and Rules: Siebel eBusiness Application Integration Volume IV |
