Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
XML Reference: Siebel eBusiness Application Integration Volume V > Siebel XML Converters > EAI Integration Object to XML Hierarchy ConverterThe EAI Integration Object to XML Hierarchy Converter can be used if additional types of XML processing are needed, such as adding new elements, attributes, or envelopes to in-memory integration object property sets. XML Hierarchy property sets can be manipulated using eScript and Siebel VB. |
XML Reference: Siebel eBusiness Application Integration Volume V |
