XML Reference: Siebel eBusiness Application Integration Volume V > XML Integration Scenarios > Scenario 2: Integration Using External XML and an XSD or DTDThis scenario presents general steps for setting up an integration based on incoming XML which has been defined in an XSD or a DTD. |
| XML Reference: Siebel eBusiness Application Integration Volume V |
